Discussion topic: WiFi issue
Message posted on 05 Aug 2025 07:57 AM
WiFi issue
Hi there,
my WiFi isn't working but showing it's working. Could you fix this asap as I am using it for working from home.
thank you
Message posted on 05 Aug 2025 08:07 AM
Re: WiFi issue
We can't fix it. We are customers here like yourself. You aren’t contacting Sky Customer Services here.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
