Discussion topic: Broadband problem to connection
This message was authored by: SimonaG
I wanted to ask you to send someone to fix the internet because it's not working, the last light on the broadband is red. I tried turning the broadband on and off a few times but it doesn't work, it's the same, the last light remains red.
Re: Broadband problem to connection
@SimonaG
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
