Discussion topic: WiFi n sky box
Message posted on 16 Dec 2025 05:54 PM
WiFi n sky box
Keep getting response issues with WiFi broadband I had a replacement box arrived all hooked n same issues as yesterday ie WiFi broadband issues
i have reset using wps button re input WiFi password same issues WiFi network keeps dropping in out n then stating issues with WiFi broadband
Message posted on 16 Dec 2025 06:06 PM
Re: WiFi n sky box
@Pav53 reolacing a hub with another unit will never over come issues with poor WiFi signal in your home. The main factors affecting WiFi speeds are the layout and type of construction of your home. You could ask Sky for an extrnder if you pay for their WiFi Max package.
Message posted on 16 Dec 2025 06:07 PM
Re: WiFi n sky box
@Pav53 What replacement box are you talking about?
