Discussion topic: Why does my wifi stop working randomly at night
This message was authored by: Lisa408
A few times my WiFi disconnects in middle of night but when I do a health check it says its all ok but red light on box
Re: Why does my wifi stop working randomly at night
@Lisa408
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If you’re still having problems you may need to contact Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline when the lines reopen.
Avatar for Lisa408
Right ok. Thanks will see how often it happens as only twice so far
@Lisa408
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
