Discussion topic: WiFi keeps dropping out
This message was authored by: Pfall
Hi,
the wifi has been dropping in and out of connection for last few days sometimes not even being able to reconnect up over an hour.
Re: WiFi keeps dropping out
@Pfall
Try running this line test to see if it finds any faults:
Avatar for Pfall
Hi,
it says it's all good I'm not sure what you mean by the second part?
Do you have a good or weak signal on your devices throughout your home ?
Avatar for Pfall
Hi,
it says good?
Have you rebooted your broadband hub at the mains, so leave it off for a few minutes before powering it back up.
