Discussion topic: WiFi keeps dropping out
Message posted on 09 Nov 2025 02:41 PM
My WiFi keeps dropping out
Message posted on 09 Nov 2025 02:43 PM
Re: WiFi keeps dropping out
@Demmo
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
