Discussion topic: Internet issue
This message was authored by: Millsie77
Internet issue
Internet is very
Re: Internet issue
@Millsie77 wrote:
Internet is very
@Millsie77
Good? Fast?
HAPPY NEW YEAR
Avatar for Millsie77
Re: Internet issue
Don't know why rest of post didn't post! Is very slow and keeps cutting out
Re: Internet issue
@Millsie77
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
HAPPY NEW YEAR
