Discussion topic: Sky broadband
Message posted on 09 Nov 2025 02:07 PM
Sky broadband
Tested my WiFi and broadband connection on the Sky app it says it's all fine but the hub keeps flashing orange on the internet?
Message posted on 09 Nov 2025 02:10 PM
Re: Sky broadband
@SeanEdgar
Use this link to check to see if there are any broadband issues or outages nearby, even if you’ve already tried it ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
Message posted on 09 Nov 2025 02:21 PM
Re: Sky broadband
Tested it all, no outage. When I text both WiFi and broadband says it all looks good. But internet keeps flashing orange.
I can't find Sky number anyway to call just takes me to all options to find answers. Do you happen to have it?
thanks
Sean
Message posted on 09 Nov 2025 02:22 PM
Re: Sky broadband
Included in my first post…
Message posted on 09 Nov 2025 02:24 PM
Re: Sky broadband
Hi never had a landline put in, is there a normal phone number?
Message posted on 09 Nov 2025 02:26 PM
Re: Sky broadband
You have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine. It may be worth buying a cheap handset for the future as calls to Sky are free.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟦 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟦 online help via this link
https://www.sky.com/help
🟦 Sky Assistant 💬 should also be available via
🟦 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
