Discussion topic: WiFi keeps dropping out.
This message was authored by: MurrayK89
WiFi keeps dropping out over last 24hrs. Tried resetting hub but not helped.
Black hub has 4 green lights on front.
power - green light
internet- turns orange
Wifi- green light
voice- turns orange
this happens constantly throughout the day, after couple mins all lights green again.
Re: WiFi keeps dropping out.
@MurrayK89 In your case would run the diagnostic service to see if the line has developed a fault, link is below but you may have to run it over a mobile data connection if your broadband is having the issue!
Try running the line test here to see if any faults are found:
