Discussion topic: Sky Box no signal or lights
Message posted on 24 Aug 2025 11:47 AM
Hi no power lights on sky Box no Internet. Test is showing all good
Message posted on 24 Aug 2025 12:12 PM
Re: Sky Box no signal or lights
@david+mcgivern
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
