Discussion topic: WiFi keeps cutting out
Message posted on 03 Dec 2025 07:38 AM
Message posted on 03 Dec 2025 09:28 AM
Re: WiFi keeps cutting out
@Peaky+blinders Run the test to see if anything is found with your connection!
Try running the line test here to see if any faults are found:
