Discussion topic: WiFi keeps cutting off
This message was authored by: Kennedy3
My WiFi has been cutting out for the past few days and disconnecting to all my devices. When I run through the testing is says everything is fine and looks good every single time. It's infuriating. I think my broadband devices and wires are judt knackered as they're a few years old but I cannot contact any support to help with this or even get someone to look at it. I work from home most days and pay extra for faster WiFi and it doesn't even work for me half the time.
Re: WiFi keeps cutting off
Hi @Kennedy3 Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
I am NOT a Sky Employee
Avatar for Kennedy3
It doesn't really provide much info Broadband Connected WiFi Enabled WiFi Network Name (SSID) SKYZ7SZ5 WiFi Network Visible Yes Current WiFi Channel 1 (2.4 GHz), 36 (5 GHz) WiFi Encryption WPA2-PSK VoiceConnected
Avatar for Kennedy3
@jamesn123 It doesn't really provide much info Broadband Connected WiFi Enabled WiFi Network Name (SSID) SKYZ7SZ5 WiFi Network Visible Yes Current WiFi Channel 1 (2.4 GHz), 36 (5 GHz) WiFi Encryption WPA2-PSK VoiceConnected
@Kennedy3
Yes it does, if you follow the instructions to the end. The info you are quoting is not what we are looking for
