Discussion topic: WiFi issues
Message posted on 16 Oct 2025 02:16 PM
WiFi issues
For the past week my WiFi goes off at least 10 times a day. I have re booted it, disconnected it took all the leads out to try and solve the problem but it still keeps happening .help please
Message posted on 16 Oct 2025 02:54 PM
Re: WiFi issues
First, you need to check if you have a live broadband connection to your router:
Openreach FTTP ONT modem:
https://www.bt.com/help/landline/lights-on-the-openreach-modem
The Nokia modem is the latest openreach ONT.
Cityfibre FTTP ONT modem:
https://freeola.com/support/cityfibre-ont.html
Then check if your router is working:
Then check the sky service:
https://www.sky.com/servicechecker/broadband
https://www.sky.com/servicechecker/broadband/checks
https://www.sky.com/servicechecker/wifi/checks (don’t need to do if you have turned wifi off e.g. to use your own mesh system)
Then with this info call sky
