Discussion topic: WiFi issues
This message was authored by: Beckyanddave
WiFi issues
All yesterday and today internet and voice keeps cutting off numerous times, I have turned the router off and on again but nothing is resolving the issue
Re: WiFi issues
@Beckyanddave
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
