Discussion topic: WiFi dropping out
This message was authored by: Yorkshirepud
WiFi dropping out
Broadband keeps losing connection briefly and reloading - it has happened 5 times now since around 3.30pm (Berkshire area)
Re: WiFi dropping out
@Yorkshirepud
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
