Discussion topic: WiFi issues
This message was authored by: Anonymousone
WiFi issues
My WiFi keeps dropping and a lot of times my internet browser won’t load unless I switch to my data but the wifi speed test keeps saying it's okay but it's clearly not okay
Re: WiFi issues
@Anonymousoneblack or white router from Sky? When these problems are happening does the lights on the router change colour?
Avatar for Anonymousone
Re: WiFi issues
It's a black router and I have not thought to check the lights. I will do that next time. What is your advise if it changes color?
Re: WiFi issues
@Anonymousone  Use the link below to guide you through what the issue is and what directions it gives to fix the fault.
