Discussion topic: Internet keeps dropping every 2-3 mins
Message posted on 11 Aug 2024 06:43 PM
Message posted on 11 Aug 2024 07:37 PM
Re: Internet keeps dropping every 2-3 mins
Message posted on 11 Aug 2024 07:46 PM
@Hs1992 & @Elle19 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 11 Aug 2024 08:09 PM
Happening same as well need a solution please
Message posted on 11 Aug 2024 09:00 PM
@Navmann Follow the directions I posted above.
Message posted on 11 Aug 2024 10:05 PM
Already did everything you mentioned. Ran the service checker atleast 10 times. Keeps popping up green.
Message posted on 11 Aug 2024 10:19 PM
Same thing keeps happening with my WiFi works for abit and then keeps dropping off
Message posted on 11 Aug 2024 10:27 PM
This is what I’m facing now and I need to restart my router every now and then. Very frustrating
Message posted on 12 Aug 2024 08:02 AM
@Hs1992 Did you follow up by clicking on broasdband or just to the service checker screen?
Message posted on 18 Aug 2024 01:21 PM
The problem is, it only connects to check the service when it is connected and working fine. When the service drops out it cannot connect to check the service so just sits spinning.
Every check comes back green because it won't check when it's not working 🤷♀️
Message posted on 18 Aug 2024 05:58 PM
@Elle19 That check should work on mobile data or you would never find a fault otherwise.
Message posted on 18 Aug 2024 06:20 PM
But that's the point, it doesn't work. It just hangs and shows a spinning icon until the point connection is restored then it says it's fine. The only response other than that is literally 'we cannot connect right now, try again later' which is ridiculous because it doesn't let you log that fault!
Message posted on 18 Aug 2024 06:43 PM
@Elle19 Is this during the service check or is this when you click on the broadband button?
Message posted on 18 Aug 2024 07:09 PM
During the check. I sign in, go to check services, check broadband and it either hangs until it reconnects or says try later. Never actually admits there is a problem when it cannot connect! When there is obviously a problem or it would connect straight away.
I give up. Would leave immediately but this is stopping me proving there is a service issue so I will have to pay hundreds to get out of the contract.
I work from home sometimes and it is causing issues with work.
Message posted on 19 Aug 2024 12:38 PM
@Elle19 I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147/
