Discussion topic: WiFi issues with PS5
Message posted on 02 Feb 2024 06:53 PM
I am having lagging issues with online play with my sky hub. Wired connection is fine and I had no issues when I was with BT. This seems to be an issue with the router. Does anybody think the new Sky max router will improve the experience? I have to trail a patch cable across the living room every time I play online and it's annoying. Many thanks in advance for your advice.
Message posted on 02 Feb 2024 09:45 PM
Re: WiFi issues with PS5
@DCrush gaming overcwifi is always going to be dodgy as interference is a risk. That you got away with it when you had BT was lucky. If an ethernet is possible it is strongly recommended. The Wifi Max hub can use higher 5GHz channels than the SR203 which might be better if the PS5 is close.enough to the hub for those to work but its not certain..
