Discussion topic: WiFi issues not working
This message was authored by: Dave02
WiFi not working. Tv not working. Issues since been upgraded I'm out atm but mither in law is at my house with my children and can't do anything. With no internet
Re: WiFi issues not working
@Dave02
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
▪️I AM NOT A SKY EMPLOYEE ▪️
