Discussion topic: WiFi issue
This message was authored by: Creativeturle
WiFi issue
Got no Wi-Fi or Internet what's going on
Re: WiFi issue
@Creativeturle
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Avatar for Creativeturle
Level 0 icon
Re: WiFi issue
Hi I've tryied this and still getting no where
Re: WiFi issue
@Creativeturle
As stated above… if you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Level 0 icon
Re: WiFi issue
No phone working
Re: WiFi issue
@Creativeturle
Call Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn't allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka 'the bot') which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
