Discussion topic: WiFi not working
Message posted on 08 Jul 2026 06:23 PM
WiFi not working
WiFi isn't working. Have tried resetting the router but hasn't helped.
Message posted on 08 Jul 2026 06:42 PM
Re: WiFi not working
@Andrew355
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
