Discussion topic: WIFI NOT CONNECTING IN OTHER ROOM IN HOUSE
This message was authored by: SharmaHarrison
Want to connect TV Fire Stick ..but WiFi not strong enough
This message was authored by: Me134
Re: WIFI NOT CONNECTING IN OTHER ROOM IN HOUSE
With a Firestick the first thing to do is to put an HDMI extender cable between the TV and the Firestick. Try and get it well away from the TV so that the signal doesn't have to pass through the TV screen (this also helps with heat BTW).
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
