Discussion topic: No internet connection
This message was authored by: Felixnfingers__
Light on router is fading in and out.
tested WiFi connection on my Sky app. Says it's all good, but it's not
This message was authored by: rona1
Re: No internet connection
i'm having the same issue
This message was authored by: ThereseBP
Having the same issue currently as well
This message was authored by: Dogank
Having same issue router is green and no internet
This message was authored by: Ire1
I got a text message this evening to say essential maintenance is going to be carried out tonight, but it did say how long it would be down for.
This message was authored by: Niz1
I just join sky in 3 months this is the second time this has happened
Bad service
This is the second time since joining sky i have ad this issue. What is going on. When I had tested the router and wifi it says everything is fine and working order. What a bunch of lie. They definitely need look the testing
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you still have broadband problems after 7am use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
