Discussion topic: WiFi issue
This message was authored by: Rosie_24
WiFi issue
My sky WiFi seems to drop in and out after 10pm at night but is fine every other time of day.
Re: WiFi issue
@Rosie_24 assuming the hub is staying connected (see https://www.sky.com/help/articles/hub-lights-explained-start) then  it is most likely somecform of interference most likely from your neighbours' networks . Rebooting your hub may help,as that makes the hub find the least congested channels. Beyondcthat you are looking at impriving thecwifi in your home perhaps by buying https://www.sky.com/help/articles/sky-wifi-max
The other sources of interferencecis electrical equipment in your home so think zbout things youvswitch on at that time etc.
