Discussion topic: Upgrade Replacement Hub
Message posted on 03 Feb 2025 04:55 PM
I've received an new upgrade hub for my broadband to replace and old one.
The instructions says don't install until activation date on Box but there no date on the box.
1. Can I plug it anyway and will it work.
2. Do I use my existing wireless name and password or the one that came with new box ?
Neil
Message posted on 03 Feb 2025 07:32 PM
Re: Upgrade Replacement Hub
You can use it straight away as there is no activation date as you are not a new customer to Sky.
You will need to connect your devices to the new wireless name and use the network key on the small card that came with it as the password.
Message posted on 04 Feb 2025 07:31 AM
@Neil164 you can change the SSID password if you want see https://www.sky.com/help/articles/find-and-change-your-wireless-password
