Discussion topic: WiFi issue
This message was authored by: Suryakanth
Message posted on 06 Jan 2025 03:41 PM
WiFi issue
I'm facing frequent sky broadband issue here. I work from home and this issue may result in loosing my job.
Find out more
Message posted on 06 Jan 2025 03:45 PM
Re: WiFi issue
Perhaps explain the issue you're having but remember that Sky Broadband is a domestic subscription and if you're that dependent on it to keep your job you should maybe consider a business subscription which would obviously cost more.,
