Discussion topic: No network externally and no internal routing. or i
This message was authored by: CraigR1969
Message posted on 09 Oct 2024 09:15 AM
No network connectivity, even though internet and WiFi lights are active (voice is amber). Sky check says all ok, but not. Also seems no internal routing as all local devices using sky router are unable to see each other. Tried power reset and button reset on rear, but no result.
This message was authored by: Kalbarcs61
Message posted on 06 Jan 2025 03:40 PM
Re: No network externally and no internal routing. or i
There is not lights on the route
