Discussion topic: WiFi isn’t working
This message was authored by: Paul604
WiFi isn’t working
My WiFi says it is working and connected. But the signal is weak. And says weak security when I try reconnecting my phone.
Re: WiFi isn’t working
@Paul604 Iphone per chance!
Avatar for Paul604
Level 0 icon
Yes always been fine. Also my firestick won't connect either .
@Paul604 Have you changed hubs? You may wish to switch the hub off for 30 minutes to see how it goes when restarted.
Avatar for Paul604
Level 0 icon
No not changed anything. Was fine until last night.
