Discussion topic: No wifi
This message was authored by: Jozefweill
No wifi
WiFi is currently not working
Re: No wifi
@Jozefweill
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
