Discussion topic: WiFi is weak
This message was authored by: Ruthrex212
Message posted on 05 Sep 2026 10:13 PM
WiFi is weak
My WiFi is not working in my living room
Find out more
Message posted on 05 Sep 2026 10:38 PM
Re: WiFi is weak
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
