Discussion topic: WiFi intermittent
This message was authored by: vikkib7
WiFi intermittent
My WiFi is intermittent and affecting my work - when I test it states everything is ok. However I can assure you it's not and it's very slow and intermittent
Re: WiFi intermittent
@vikkib7
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
