Discussion topic: WiFi not working
Message posted on 17 Oct 2025 09:06 AM
WiFi not working
Past 3 days our team if I had constantly dropped out. Have tried all the necessary checks and things but it's not working.
Re: WiFi not working
It's not working
Message posted on 17 Oct 2025 10:35 AM
@Tommykat26
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
