Discussion topic: WiFi drops out
This message was authored by: CarolynFaz
WiFi drops out
WiFi not working for about 10 minutes , when doing a check on the app it says all ok but it isnt
Re: WiFi drops out
@CarolynFaz
The app looks for issues in your area so if there are none then it might not show any issues if it is an issue with your line only so instead try running this line test instead:
