Discussion topic: Upstairs to keeps disconnecting
Message posted on 18 Aug 2026 09:29 PM
My upstairs tv keeps disconnecting from the internet, so I can't watch it and keeps sending me round in circles trying to reconnect
Message posted on 18 Aug 2026 09:39 PM
Re: Upstairs to keeps disconnecting
If your broadband hub is downstairs then a poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
