Discussion topic: WiFi intermittent issues
This message was authored by: Pitbull1709
My WiFi is not working properly. Sometimes it will be fine, then it will drop out, and the light will go amber/red. It will then go to pulsing green and back to white. HOWEVER, it keeps asking me to sign in as if it were a public WiFi. I have restarted the router, restarted the fibre box, and done a factory reset on the router through admin. None of this has worked, and I keep having the issue.
Re: WiFi intermittent issues
@Pitbull1709
Try running this line test to see if it finds any faults:
Avatar for Pitbull1709
Hi, done that, it comes back fine saying it all looks Ok. On the broadband test, it says your sky broadband looks good. WiFi check is the same.
