Discussion topic: WiFi dropping out
Message posted on 18 Dec 2025 06:35 PM
WiFi dropping out
Message posted on 18 Dec 2025 07:28 PM
Re: WiFi dropping out
@Bronwyn123 If everything else is working fine then the issue is with your mobile devices only, what are they that may help and what sky hub are you using?
Message posted on 18 Dec 2025 07:33 PM
Motorola Edge 40 and iPhone 8 Plus, but have both worked fine previously. We have the Sky Max Hub
Message posted on 18 Dec 2025 07:39 PM
@Bronwyn123 Do they both work fine if you keep them near to were the sky hub is, try that first? Other suggestion is to have a look at the wireless securities on the Max hub with your app, if on WPA3-T drop it back to WPA2-PSK mode off operation!
