Discussion topic: SKY network unrequested change
This message was authored by: E5PKR
my SKY2N7WM network constantly changes to SKYB471D
Re: SKY network unrequested change
@E5PKR Are you sure that is not another sky user system close by to you or have you set and changed a sky Hub ssid and it's reseting back to a default on a sky Hub, you have NOT supplied enough info on your post!
