Discussion topic: WiFi dropping out
This message was authored by: Stacey83
Message posted on 11 Jan 2025 11:37 PM
WiFi dropping out
our wifi keeps dropping out, devices keep buffering. Intermittent faults, not all the time but it's affecting daily use.
Find out more
Message posted on 12 Jan 2025 08:00 AM
Re: WiFi dropping out
@Stacey83 as people wrongly use the term "WiFi" to cover boththe broadband connection to your home and the WiFi connection from the hub to the device can you confirm what issue that you have as the helpmrequired is different.
Briefly if the connection yo the hub drops then its likely a line issue however if the hub stays connected then its likely to be thecwifi in your home.
