Discussion topic: My WiFi doesn’t work
Message posted on 12 Jan 2025 01:17 AM
Hello,
in last few months my WiFi is working very bad !
we need somebody to fix that
Message posted on 12 Jan 2025 07:56 AM
Re: My WiFi doesn’t work
@Ionut6 You are not talking to Sky by posting in the forum. However you will need to be more specific as to what is wrong. If speeds to the hub are lower than the guarantee or the hub is losing connection multiple times a day then Sky should get your line checked. Good placecto start iscthe service checker in the.My Sky app which checks speeds daily.
If however the problem is poor wifi in your home thst isnt something Sky can help,with without charging you more.
