Discussion topic: WiFi dropping from laptop when on important work calls
This message was authored by: Squarebear
My WiFi connection keeps dropping out. I work from home as an EMERGENCY CALL Handler, and you can understand the importance of the connection while on a urgent call. Someone pls help
Re: WiFi dropping from laptop when on important work calls
@Squarebear
Could you post your router statistics as shown below
Avatar for Squarebear
@cookiemonsteruk
Can't seem to get the reply to you???
@Squarebear wrote:
@cookiemonsteruk
@Squarebear
You haven't submitted the image of the stats yet. We then have to approve it before it becomes visible to all.
Sky Hub Status
This page shows the current settings for your Sky Hub. We have preconfigured your Sky Hub with the optimum settings. This is a read only summary page, if you wish to change settings use the menus at the top of this page.
  • Select Show Statistics to see your Sky Hub performance statistics such as the number of packets sent and number of packets received for each port
  • Select Connection Status to see information about your current connection
Systems Details
Manufacturer Sky
Model ER115
Firmware Version 4.13.0704.R
DSL Firmware VersionA2pv6F039m1.d24m
Modem
Modem StatusConnected
Traffic Type:PTM
Line Rate - Upstream (Kbps):19999
Line Rate - Downstream (Kbps):79999
IPv6 Loopback (Removed)
Broadband Port
MAC Address(Removed)
IPv4 Address(Removed)
Network TypeMER
IPv4 Subnet Mask(Removed)
Gateway IPv4 Address(Removed)
IPv4 Domain Name Server(Removed)
Gateway IPv6 Address(Removed)
IPv6 Domain Name Server
IPv6 Global Address(Removed)
IPv6 Link Local Address(Removed)
IPv6 Delegated Prefix(Removed)
LAN Port
DHCPv4On
IPv6 (Removed)
DHCPv6On
Wireless Port
Name (SSID) (Removed)
Region Europe
Current Channel 11 (2.4 GHz), 36 (5 GHz)
Wireless APEnabled
Broadcast NameYes
Connection Status Show Statistics
System Details
Basic information about your Sky Hub.
  • Manufacturer - maker of your Sky Hub.
  • Model - model number.
  • Firmware Version - this is the current software your Sky Hub is using.
  • DSL Firmware Version - This is the version number of the low-level DSL firmware. This is contained within the Sky Hub Firmware.
Moderator note: Removed personal details
@Squarebear
Those are not your stats, follow the instructions to the end.
I am NOT a Sky Employee
Router Statistics
System Up Time: 97:49:25
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 9372604 14825779 0 6128 52446 52:14:46 LAN Up 2368337 102731 0 6932 0 97:49:25 WLAN (2.4 GHz) Up 4068348 4141787 0 6390 473 97:46:54 WLAN (5 GHz) Up 57997320 40295838 0 0 0 97:46:41
Broadband Link Downstream Upstream Connection Speed (Kbps) 79999 19999 Line Attenuation (dB) DS1:6.9    DS2:14.3    DS3:20.5 US0:4.3    US1:12.4    US2:16.3 Noise Margin (dB) DS1:10.9    DS2:10.9    DS3:10.8 US0:15.3    US1:15.5    US2:15.4
Poll Interval:
Seconds (at least 3s):
This message was authored by: Sarah533
I have tried to clink this link but it doesn't work.  Can you please tell me how to access the hub settings, we have moved to sky today and my partner works from home, the connection drops out every few minutes.  Sky have been useless when I have called them, regretting moving right now!  Any help please ?
@Sarah533 White or Black sky hub?
I have turned off shield protect,  I have tried resetting devices and router,
everything else is fine,
no vpn on this laptop,
