Discussion topic: WiFi down
This message was authored by: AS1097
WiFi down
My WiFi seems to be down again. I had engineers out the other week and it appeared to be okay but it's started playing up again. There's an amber light on the WiFi and voice. I've restarted it all but the same keeps appearing. The app says everything is working fine but on my end, nothing seems to be working
Re: WiFi down
@AS1097 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
