Discussion topic: WiFi down
Message posted on 24 Jun 2025 01:23 AM
WiFi down
Message posted on 24 Jun 2025 04:54 AM
Re: WiFi down
When this happens between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Should it still be off later use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
