Discussion topic: WiFi not working or broadband
This message was authored by: Paul_2
No broadband or wifi
Avatar for Paul_2
Level 0 icon
Re: WiFi not working or broadband
Correct
This message was authored by: Missu1
Same here
When this happens between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't come back on after 7am use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
