Discussion topic: WiFi down again
Message posted on 28 Apr 2025 11:38 PM
WiFi down again
Not happy at the work being down since 6.30om ! Sort it out
Message posted on 29 Apr 2025 03:37 AM
Re: WiFi down again
@Elliethornhill7
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
