Discussion topic: Fix problem or I will cancel subscription
Message posted on 28 Apr 2025 11:11 PM
Broadband not connecting, tried all your proposals, fix or I cancel
Message posted on 29 Apr 2025 03:40 AM
Re: Fix problem or I will cancel subscription
@r+lawson wrote:
fix or I cancel
@r+lawson
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If it's an Openreach issue moving to another OR infrastructure ISP will move the issue with you.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
