Discussion topic: Broadband down
This message was authored by: JenMcS
Broadband down
Sky Broadband down since midnight.
Tried resetting box etc but middle 'broadband' light stays red (other two lights green as normal) and Sky Service checker says there are no issues!
Anyone else? I have to WFH in a few hours!
Re: Broadband down
@JenMcS
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by the morning (7ish), use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
