cancel
Showing results for
Search instead for
Did you mean:
WiFi does not work upstairs
SOLVED
Susie531
Level 1
Solved!
We had new fibre broadband installed yesterday and with router in a new place. The signal does not reach all parts of the house. Think we need a booste
1 ACCEPTED SOLUTION
Accepted Solutions
cookiemonsteruk
Level 16
Solution
Re: WiFi does not work upstairs
Message contains a hyperlink
@Susie531
@savo2309
You need to call sky on 150 from your sky landline or
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
View solution in original post
4 REPLIES 4
savo2309
Level 1
Same for me but we've had ours a bit longer. How do you purchase a booster??
cookiemonsteruk
Level 16
Solution
@Susie531
@savo2309
Susie531
Level 1
Thanks. All sorted and booster coming soon
Daws74
Level 1
Hi,
I did the link you suggested and it just took me to the testing section. Everything does look fine because downstairs is okay it's just upstairs. How do I get to the part with regards to boosters? Thanks in advance
