Discussion topic: WiFi dead zone
This message was authored by: Mcp31
WiFi dead zone
I live in an older property with two thick internal brick walls which effectively break the house into 3 segments.
My wifi signal is either weak or non existent beyond the central area and I'd like to get the boosters from sky.
How do I go about this?
Re: WiFi dead zone
@Mcp31 You need to call sky direct, you also require to have the Sky Max product with the addon to the package to qualify as such, see the details all linked below.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Re: WiFi dead zone
@Mcp31 Due to your internal construction the wireless wifi boosting mesh system may just not be the best way for you to get the required, so have linked the information and you possibly should looks at Powerline Wireless Wifi location, will not be a speed demon but may be well better suited operation wise.
Powerline Adapters | TP-Link United Kingdom
