Discussion topic: Orange light is flashing
This message was authored by: Carl+Harra
Internet has gone off, orange light is flashing then goes off completely then starts to flash again
Re: Orange light is flashing
@Carl+Harra
See further down about the various hub lights…
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
