Discussion topic: WiFi cutting out
Message posted on 05 Feb 2025 05:03 PM
WiFi cutting out
I've tested my WiFi, my hub and my connection all comes back fine but internet keeps cutting out then coming back on and internet light and voice light keeps going orange, restarted device - no improvement.
please help sort this!
Message posted on 05 Feb 2025 05:28 PM
Re: WiFi cutting out
@Sam337
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
